Old 07-11-2003, 01:52 AM
kdio kdio is offline
kdio is off the scale
Went to put my H2 in park tonight and the whole base (transmission and cup holders) popped up. Now I can't get the key out of the ignition, unless I force the shifter forward to lock it into park. Has this happened to anyone else.
Kirk
03 H2 Sunset Orange Polished Magna Charger w headers & cold air intake, 37" MTRs w Weld Mountain Crushers, GPS Nav. & 2 rear LCD TVs w DVD, Extreme Tube steps
Kirk
Old 07-11-2003, 01:21 PM
It sounds like the plant put that section together right before lunch
Old 07-11-2003, 10:26 PM
NCHummerman NCHummerman is offline
NCHummerman is off the scale
The whole set up including the cup holders just pops back down .... I had a similar problem, in that I could not get the key out .... it was that the transmission would not go into park. A friend fixed it by popping the whole shifter cover including cup holder set up, and adjusted the shifter for me. There are some adjustments in there under the rubber strip that slides with the shifter ...
Michael
Pewter Hummer H2
Northern California
www.zootsuitstore.com
Michael
Pewter Hummer H2
Northern California
Old 07-12-2003, 06:05 PM
I brought my H2 to the dealer yesterday to get it fixed. It turned out to be the aftermarket GPS system installed in the truck. The wires were run inside the center console and somehow moved which blocked the rubber piece that slides with the shifter. This forced the rubber piece up and popped the cover up. Simple fix that took them 10 minutes to fix. Luckily the dealer installed the GPS system in the truck, so no charge.
