Old 05-28-2005, 12:24 PM
I have replaced the LR marker fuse at least 6 times recently. I pulled the DRL jumper that I had for years, just in case. Replaced the relay. It keeps blowing the fuse.
A little help.
A little help.
Old 05-28-2005, 02:08 PM
tower's Avatar
tower tower is offline
Pull the fuse and the bulbs. Test resistance between the <span class="ev_code_RED">+</span> & - wires at the bulb end of the harness. You should get no continuity. If there is any, the wiring is the problem. If you pulled power for the DRL's from the markers rather than the trip wire for the DRL's from that marker lamp circuit, you may have fried the insulation somewhere and created a soft intermittent short.
Is it blowing the fuse instantly or after it's been on for a while?
Old 06-02-2005, 10:46 PM
New fuse panel did the trick. Thanks for the help.
Old 06-03-2005, 03:23 AM
tower's Avatar
Thanks for the update,Adam. Was it the IP box by the driver's door or the power distribution box under the hood?
