Old 12-12-2005, 11:48 AM
Pinhead Pinhead is offline
Pinhead is off the scale
Anyone know a good place to get 12 volt Christmas lights to decorate roof rack with ?????
YELLOW 2005 6\" lift 37\"XTerrian Tires Reverse camera In dash nav system DVD 4 monitors Safari rack Off road lights Fender flares AAAAugha horn
Old 12-12-2005, 11:57 AM
Dan Dan is offline
Go to WalMart and get a power inverter and use regular outdoor lights. They sell cheapie inverters that plug into the lighter outlet. Check wattages first though...
Old 12-12-2005, 12:04 PM
ree's Avatar
ree ree is offline
Go to WalMart and get a power inverter and use regular outdoor lights. They sell cheapie inverters that plug into the lighter outlet. Check wattages first though... </div></BLOCKQUOTE>
And get one with enough wattage so that you can run it continuously. If you get just the minimum wattage, they're typically only rated for intermittent use (a few minutes at a time).
'03 pewter base H2
Old 12-12-2005, 12:32 PM
Klaus's Avatar
Klaus Klaus is offline
... And be prepared to be stopped by the police if you plan on driving with the lights on.
Old 12-12-2005, 01:09 PM
ree's Avatar
ree ree is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Klaus:
... And be prepared to be stopped by the police if you plan on driving with the lights on. </div></BLOCKQUOTE>
If he's hellbent on being able to run with them, he might be able to get away with it provided he stays away from red, blue, and flashing lights. He might get pulled over still. I'm too lazy to check CA statutes to substantiate this though
'03 pewter base H2
Old 12-12-2005, 01:35 PM
jfox jfox is offline
jfox is an unknown quantity at this point
We've decorated our roof rack every year with garland and lights. Never had a problem. Just run an extension cord through the door and attach to the power inverter. I'll post a picture this evening of our "sleigh" with lights.
J.
