Old 01-15-2006, 12:10 AM
Grandman Grandman is offline
Grandman is off the scale
I find nothing in search , How can one over ride the locker kick out . There should be a simlple method to wire up a new switch to lock the locker in High range and will defeat the kick out at 20 mph for the locker .
They do this on the Rubicon by adding a new switch and wiring it in . Any one know ?
2006 H 3
2006 H 3
Old 01-15-2006, 03:54 AM
cherokeekid cherokeekid is offline
cherokeekid is off the scale
why not yank the wires and see if you can jsut run 12v to the thing then just wire it on a completely sepereate circuit?
Old 01-15-2006, 03:56 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Grandman:
They do this on the Rubicon by adding a new switch and wiring it in . Any one know ? </div></BLOCKQUOTE>
You're trying to make it explode?
Old 01-15-2006, 11:11 AM
Yes, there is a way to bypass with another switch, not sure if it is a 12V feed or smaller since it is turned on/off by the TCCM.
However, I wonder why GM and Eaton decided to limit the operation to a particular speed?
Old 01-15-2006, 12:20 PM
HURF HURF is offline
HURF is off the scale
However, I wonder why GM and Eaton decided to limit the operation to a particular speed? </div></BLOCKQUOTE>
Same reason we say things like the water fording restrictions etc....
CYA.
GM doesnt think that the majority of H3 drivers could handle a locked rear, at a speed higher than 20mpg.
Eaton E-lockers are used in many aftermarket applications and have no speed restrictions on them.
It took about 24hrs after the intro of the Rubicon before a Jeeper had a bypass for the same annoying feature. Its all over the net.
Almost every Rubi owner I wheel with has done the bypass and has had no issues.
I guess we will have to figure this one out ourselfs G-Man.
I try to get some info when I get back to work after MLK
HURF
Restored \'82 Jeep CJ7 ,258,.40 over,,Comp Cam,,GM HEI,,Borla Header,,Weber 38,,T5,,D300,,D30,,4:56,,Detroit,,AMC20,,trussed,, Detroit,,Warn full floater,,trXus 33X12.5X15
Hummer Test Driver
Old 01-15-2006, 12:50 PM
Well, I could tell you today exactly what you need to do, which wires to tap into at the I/P with a switch. However, if it was truly programmed for safety reason I will allow someone else to supply this information.
Old 01-16-2006, 01:22 AM
Some one like GM who gets sued over any and every thing tries to CYA to a fualt .
Iv driven so many locked front and rear that im not worried but Gm is . Soccer moms scare the H out of them .
2006 H 3
Old 01-16-2006, 01:23 AM
Well, I could tell you today exactly what you need to do, which wires to tap into at the I/P with a switch. However, if it was truly programmed for safety reason I will allow someone else to supply this information. </div></BLOCKQUOTE>
Check your pms
HURF
Hummer Test Driver
