Old 03-31-2006, 10:52 PM
HummerHawaii's Avatar
HummerHawaii HummerHawaii is offline
HummerHawaii is off the scale
Has anyone know how to install the hollow metal pipe that goes in the headrest? i got the cutting part but rewiring it is confusing...aarrrgh!
thank you!
Sup. Blu H3/DvD Navigation+DvD Changer/Rear CCD IR Camera/ SplashGuard, LocKing Billet gas cap, 4" Step Nerf Bars/Underbody lightning, and adding..
Old 04-01-2006, 12:35 AM
kodiakz kodiakz is offline
kodiakz is off the scale
Errrrhhh, what 'hollow' metal pipe would that be? If you are cutting in the monitors, you will keep the solid posts intact and run your wires out and down the side (yes, visible wiring)of one of the posts. Sorry if I am misunderstanding your question, but I think that is what you are referring to.
Old 04-01-2006, 05:48 AM
No, i mean..i don't want the wires to be exposed, as much as possible i wanted to hide it. That's why i bought a hollow pipe from hardware store and i have the exact diameter, problem is, dunno how to install it, i might have to do a little metal bonding stuff..
Old 04-01-2006, 01:34 PM
Man, don't mess with the posts as those could one day save you from a broken neck in event of an accident. If you can somehow find some of the hollow chromolly steel posts that the aftermarket vendors use (and that are dot certified) then you could have those posts professionally welded into your existing headrest. I would not try to Mcgyver your posts just to hide the wire--when the headerst is down you really can't see the wire anyway if you do it right.
Old 04-02-2006, 02:29 AM
Good thought man, Thanks a lot!
Old 04-04-2006, 02:05 PM
JohPol JohPol is offline
JohPol is off the scale
I cut down a set of rubber shock covers and installed them. Hides everthing and looks nice. Colr match to the interior.
