Old 03-06-2005, 05:44 AM
franko franko is offline
franko is off the scale
Just put um on, couldnt pass up the deal!!! Had to trim 1/2"x2" off the rear traiing arm and the front rubs slightly at full lock. I am thinking of running a 1/2' spacer on the fronts anyone have experience with this? The rims are 22 x 9.5.
thanks Franko
thanks Franko
Old 03-06-2005, 06:30 AM
DH22G's Avatar
DH22G DH22G is offline
DH22G is an unknown quantity at this point
which tire are you running.. brand? i got the TOYO open country mt which sounds like what u have with that sizing... i really havent had any problems at all.. what wheel are you using? offset?
- DH22G
David
2007 Acura TL Type S
Old 03-07-2005, 01:15 PM
W1N's Avatar
W1N W1N is offline
W1N is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by DH22G:
which tire are you running.. brand? i got the TOYO open country mt which sounds like what u have with that sizing... i really havent had any problems at all.. what wheel are you using? offset? </div></BLOCKQUOTE>
DH22G, do you have lift kit or are you running stock? Do you have 37x13.5R22?
Thanks!
Old 03-07-2005, 01:46 PM
Maybe I'm confused, but did you say you cut the rear trailing arm?
Want-08 Viper, 06 M5
Old 03-07-2005, 10:57 PM
DH22G's Avatar
yea iam stock suspension cuttin the rear arms? iam lost sounds shady.. i did NO CUTTING... much have the wrong offset to ur rims u know u had to back space them since they are 13.5 wide
- DH22G
David
Old 03-08-2005, 03:17 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Posted by franko:
Had to trim 1/2"x2" off the rear traiing arm </div></BLOCKQUOTE>Uh, I think you are going to pay for that later. You better get some new rims AND new trailing arms.
Old 03-08-2005, 05:37 AM
I am running Toyo MT's on Ultra Stargazers 140's, The trailing arm lip on the bottom was cut 1/4 by 2 inches under the shock mounting bolt where it stuck out to the wheel side. The rear rubbed slightly on the right side only under hard cornering and the front does rub slightly at full lock. I spoke to one other owner with the exact same set up but he has air ride and he says no rubbing.
Franko
Old 03-08-2005, 07:36 AM
DH22G's Avatar
iam spring suspension and no rubbing in front yea full lock.. but the rear!? u need the right rim for it. offset right
- DH22G
David
Old 03-11-2005, 02:47 AM
DH22G's Avatar
post some pics franko
- DH22G
David
