Old 04-13-2006, 10:11 AM
enfuego02 enfuego02 is offline
enfuego02 is off the scale
Hey GopherH3....I had the same problem as you. I just returned my Neo ion unit. I have the factory XM unit and did hook up the XM data cable and still had XM bleeding into the ipod option. Also when I switched to just listen to XM the radio it would cut out. I got fed up and returned it. I don't have the directions for the ion unit anymore but it should have the position where the data wire is located on the XM unit itself.
