Old 03-07-2006, 12:34 AM
usmctopgun usmctopgun is offline
usmctopgun is off the scale
What kind of pressure do you all run in your Toyo Mud Tires during normal street use? Mine call for 65PSI Cold...that just sounds a little high. Thanks in advance.
Semper Fi,
Michael
Old 03-07-2006, 01:31 AM
Damn, maybe I should check mine. They're at 40 cold.
Old 03-07-2006, 06:50 PM
Originally posted by PhilD:
65 sounds a little high and I imagine the ride is a little harsh, and you'll most probably be weraing the center of the tread more than the sides.
I've settled on 45 psi, which gives me the best ride while maintaining a reasonably high tire pressure.
Thats what I thought, but the tires actually say 65 PSI Cold on the sidewall. I went with 50, but may drop down to 45 also. Thanks Phil.
Semper Fi,
Michael
Old 03-08-2006, 09:40 PM
Tah2oe's Avatar
Tah2oe Tah2oe is offline
Tah2oe is an unknown quantity at this point
My question is where can I get 35 12.50 17 MTs? I need them.
Old 03-08-2006, 09:55 PM
H2 Bill H2 Bill is offline
45 here too.
1994 Chev Suburban Blown
Old 03-08-2006, 10:48 PM
These were on ebay about a week or two ago, and they did not sell. Contact the guy, as I am sure they are still available.
TOYO M/T 35x1250x17
Semper Fi,
Michael
Old 03-09-2006, 12:56 PM
Tah2oe's Avatar
Thanks for finding this. I have contacted him and I am waiting to see if he still has them.
Old 03-09-2006, 01:56 PM
MarineHawk's Avatar
Originally posted by usmctopgun:
... but the tires actually say 65 PSI Cold on the sidewall. I went with 50, but may drop down to 45 also. Thanks Phil.
The 65 PSI is just the maximum PSI, which I think is required only when you are subjecting them to the max load (4,300 lbs per tire for the Toyo 37"). So unless you have your vehicle loaded up with about 17,200 lbs GVW, you don't need them aired up to the limit. For example, the stock BFGs have a max load of 3,195 lbs at the max PSI of 50. But, notice that near your front door hinge on the driver's side, it says that the Mfr's recommended cold PSI for those tires is something like 35.
Old 03-09-2006, 10:25 PM
Tah2oe's Avatar
A set of 4 Toyo Open Country MT 35 x 12.5 x 17 tires are on their way to me.
usmctopgun thanks.
