Old 02-18-2006, 01:58 AM
V10MOJO2TOW V10MOJO2TOW is offline
V10MOJO2TOW is off the scale
i may have a problem with shift solenoids. any input on cost and complexity of repair.
Old 02-18-2006, 08:44 AM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
Mine was not shifting down when I slowed or stopped. They replaced my ignition switch (never understood the connection)
Old 02-18-2006, 11:11 AM
intimidator intimidator is offline
intimidator is off the scale
the shift solenoids are located in the valve body. they can be replaced by removing the transmission pan.the link between ignition switches and transmission problems . is that the ignition switch becomes open and doesn't power up the transmission fuses.
Old 02-19-2006, 01:51 AM
partsguy partsguy is offline
How do you know it's the solenoids?
I have seen only two hardware problems so far.Most likely it's a software update or a Ing switch,Shoot it could also be the connector for the shifter control solenoid(in the console)The wires get kinked(can't spell but can spell kinked )and fray at the termial.
Don't pull the pan unless you know for sure,It's a pain.
Old 02-19-2006, 02:46 AM
Andre Andre is offline
Andre is off the scale
he has the same symptoms as my truck had...they changed my solenoids and everything was ok after.
