04-26-2006, 05:33 PM
Someone please explain to me why would anyone want to upgrade their sway bars to thicker ones on an off road vehicle? It seems to me that no sway bars at all is best for off road use and the thin stock ones off sort of an in-between for street & off road use.
What would the benefits be for upgrading these? I can see how they would reduce body roll on the sreet. However, thicker ones would seem to reduce articulation at the same time.
04-26-2006, 08:05 PM
to match my penis size
04-26-2006, 08:43 PM
No one says, but there is a set on ebay cheap cheap.
Originally posted by PhilD:
I don't know why you would either, unless you were racing or something. Who says you should?
04-26-2006, 09:59 PM
Easy-
When I pitch a 6400lb vehicle into a soft curve at 80MPH, I want it to tract correctly thru the turn.
When I wheel, I remove the bars. It allows the most axle travel possible.
Duh!
Want-08 Viper, 06 M5
04-26-2006, 10:19 PM
04-27-2006, 02:13 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Fastest H-Town Realtor:
Easy-
Duh!
Duh!  Read the question again
He understands what the benefits on the street are, but is asking about the best compromise for on-road and off-road, with an emphasis on the off-road part and what benefits you'd have off-road. I know if I removed mine, I'd have to use limiting straps, so it is easy to just keep them on when wheeling. </div></BLOCKQUOTE>
Guess it was kinda like:
Redundant: [adj] re·dun·dant 1-See Redundant.
04-27-2006, 06:38 PM
Circle track racing. Duh....
04-27-2006, 09:50 PM
Yea KenP:
I am working on a circle track Hummer race on dirt, except there are few takers--many on the Hummers will get beat up a bit
