Old 04-15-2005, 04:45 AM
khiarrr khiarrr is offline
khiarrr is off the scale
I have a 2003 H2, I've had it for a couple months, but my dad drove it for a couple years before that...
I recently noticed that the carpet was wet, it was pretty bad, the insulation was soaked, and the carpet was wet all the way to the second row of seats, it messed up my DVD system...
I took it to the dealer the first time, they said it was from the truck lights on the top, and they told me they fixed it...
When they gave it back to me and it rained again, the same problem occured.
After the second time, the problem still happened when I wash my car...
After their third try at it, it still leaks...
Any ideas why it's happening, or what I can do?
Any chance its a lemon?
Old 04-15-2005, 12:45 PM
Hummertech is off the scale
There are tons of posts for this. Just do some searching and you'll find it. Probably either the sunroof drain tubes restricted or something screwed up when aftermarket equipment was installed.
Old 04-15-2005, 03:18 PM
I have no sunroof or aftermarket equipment
All the posts I've found about it are on the driver side.
Old 04-15-2005, 04:37 PM
Then there is a good chance your overhead roof lights are leaking by not sealing well, or there may be a pinhole in a body seam that was not sealed up well from the factory. Or possibly a front windshield not sealed well.
You better take it back to the dealer and give them a second chance at it.
Old 04-15-2005, 05:13 PM
Spike Spike is offline
Have the dealer check the large rubber grommet inside the door jamb, where the wires from the door go into the body. That was where mine was leaking from.
Old 04-15-2005, 06:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Spike:
Have the dealer check the large rubber grommet inside the door jamb, where the wires from the door go into the body. That was where mine was leaking from. </div></BLOCKQUOTE>Spike, you and I are on the same page. That's exactly what I said in this other thread :
http://elcova.com/groupee/forums/a/t...811#3641092811
