Old 09-15-2005, 04:38 PM
wch3 wch3 is offline
wch3 is off the scale
Has anyone had a leak on the driver's side A pillar. Discovered that at the base of the pillar where it meets the windshield that water is present when it rains. It does not appear to be alot in that the carpet is dry but if you place a piece of paper in the corner, the edge that drops below the dash becomes wet.
Any suggestions as to cause and remedies?
Yellow 03 LUX with Air Suspension, PIAA Fogs on Brushguard
