Old 05-13-2006, 07:12 AM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
Default Sunroof Wind Deflector
I removed the large plastic wind deflector because I never cared for it. I think I may be missing a part. Don't these things come with a built in deflector that pops out when the roof is opened? Well, at least every other car or truck I've owned did, even the H3.
I'm assuming that the factory spring loaded deflector needed to be removed for the larger plastic unit. Can anyone validate that? If so, I am willing to trade.
2003 Yellow H2 LUX (Sold)
Old 05-13-2006, 10:56 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Sunroof Wind Deflector
The plastic one you removed is the only factory deflector for this truck, no auto one like most vehicles.
Old 05-14-2006, 02:52 AM
kacyk's Avatar
Thanks,
I called the dealer this morning before I read your reply and they said the same. IMO the huge sunroof is useless. Even with the giant wind deflector you can only open the roof half way due to heavy buffeting.
It's too bad as the one in my H3 was a great design and you could open it all the way with minimum wind issues.
Old 05-18-2006, 01:06 AM
Alan06SUT's Avatar
no buffeting if you open a window. I use mine all the time. It keeps me tan.
Old 05-18-2006, 01:37 AM
JWSchmidt3 JWSchmidt3 is offline
JWSchmidt3 is an unknown quantity at this point
You were lucky. My sunroof sucks, and will be installing the very part you are pulling off, to help eliminate the wind and vibrating. My dealership said it's a known problem, and there is no fix.
J.W.
2006 yellow H3 - Pro Comp Xtreme package
4" lift, 35's, Lux, etc.
2004 yellow Corvette Z06
2002 black LPE blown TigerShark Z06
http://public.fotki.com/JWSchmidt3/
Old 05-18-2006, 05:47 AM
dochummer's Avatar
Mine's aftermarket, and I believe it has the "pop up" deflector...haven't had the courage to pull of the ugly plastic deflector on the roof yet....
'03 H2
Old 05-18-2006, 05:48 AM
dochummer's Avatar
Kacyk, my wife's highlander doesn't have a large deflector like the H2 does, and it does have a lot of wind buffeting. Just crack the rear windows open, and it should solve the problem...
'03 H2
Old 05-19-2006, 06:15 AM
Open all the windows, the sunroof, and the rear window.... FANTASTIC!!!!
