Old 05-23-2006, 09:36 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
Default Here's my busted Differential pictures...
For those of you that are interested in what a differential looks like when it fails...
____________________________
Old 05-23-2006, 09:48 PM
mancilg mancilg is offline
mancilg is on a distinguished road
Default Re: Here's my busted Differential pictures...
looks like someone shot it
ride hard, ride soft, rridemonkey
Old 05-23-2006, 10:02 PM
It's like a little toy differential.
Old 05-23-2006, 10:14 PM
rkcrawl rkcrawl is offline
rkcrawl is off the scale
No internal shots? Bummer.
Jim O'Brien
'06 H3 Slate Blue Lux/Adv
www.etoracing.com
Old 05-23-2006, 10:33 PM
That would explain the leaking fluids
Old 05-23-2006, 10:41 PM
Mike E's Avatar
No internal. If i was there i would open it up but I had to rely on the service guy to take the pics.
Old 05-23-2006, 11:19 PM
It might have looked like this
Old 05-23-2006, 11:23 PM
deserth3's Avatar
deserth3 deserth3 is offline
I'd be interested to see the inside.
Old 05-23-2006, 11:54 PM
ketcat ketcat is offline
ketcat is off the scale
This question may have been answered in the past but.....
Is the front diff on the H3 an AAM 725? 185mm (7.28") ring gear.
Is the rear an AAM 800 or AAM 860? 205mm (8.07")or 220mm (8.66")ring gear.
Old 05-24-2006, 12:02 AM
Is the front diff on the H3 an AAM 725? 185mm (7.28") ring gear. Yes
I believe it is the 860
Old 05-24-2006, 12:04 AM
Couldn't they patch the hole? Yes, that is one destroyed axle.
GM may have requested it be returned un-opened for inspection; I would if it was my part.
Old 05-24-2006, 04:21 AM
Thanks for the help.
Old 05-24-2006, 12:11 PM
I know, thats why I was curious, to see if it was the same issue with multiple teeth broken off. Sound like in this case one of the tooth chips probably got bound beteen the pinion and a good tooth on the ring gear causing a boom with enough force to send it out through the housing.
I hate for people to be experiencing this and really hope its a problem thats been identified and fixed already. If not, there is gonna be a lot of these from people who wheel them.
Jim O'Brien
www.etoracing.com
Old 05-28-2006, 06:30 AM
some gold bond for bebe's teeth and some chewing gum for mike's hole hell those are both easy to fix on the trail
Old 05-28-2006, 06:48 AM
That's bad but in Durango at a Hummer event I was helping with tech support when we saw a guy in an H2 over rev and raise the front a foot in the air. She came back down spinning and the front diff cracked open from the center like an egg. We had to flatbed it in and they actually covered it at the Gm trailer at no charge to the dude.
Old 05-28-2006, 12:34 PM
Old 05-28-2006, 01:32 PM
Hummie2's Avatar
Hummie2 Hummie2 is offline
yep, that is one of the weak areas in the H2 also. I have see a few H2 open up like a cracked egg. Usually they are spinning and suddenly catch traction when they crack from the sudden shock load to the axle. I don't believe these H3s were spinning or broke traction at the time they broke the gears.
Those look like cast aluminum bearing caps in the picture. The caps will let things move when the strain becomes high enough. Definitely some room for improvement.
GM should cover things if they happen @ a sponsored event or Hummer Happening. Those are supposed to be controlled situations. Dealers are required to do two off-road events per year and damage to the truck there should be warrantied. I have seen one of our local dealers give a demo to customer and flatbed a broken rig back to the shop for warranty repairs more than once at Hummer Happenings. That is what customer satisfaction is all about and that customer will remember next time they are looking for a new Hummer.
Old 05-28-2006, 02:38 PM
GM should cover this under any circumstances, not just at a Hummer Happening. So far, I believe all have been covered under warranty at the dealers.
Old 05-28-2006, 04:02 PM
Hummie2's Avatar
Yes they should. Hopefully we won't hear the "THATS OFF-ROAD DAMAGE" bs that came up with the H2s.
Old 05-28-2006, 11:32 PM
Component failure is one thing; however, I can see if the case, trans or engine are dragged and pans ripped open not being covered.
