Old 05-27-2006, 11:56 PM
GeorgeSSSS's Avatar
GeorgeSSSS is off the scale
Default Bulb replacement in rear bumper [how do I do it?]
The lower brake light bulb [the one in the rear bumper] is burned out. How do I replace it without disassembling the entire truck?
Dumb question, but it's easier to ask my friends here than struggle with it.
Thanks in advance,
George SSSS
Old 05-31-2006, 06:53 AM
GeorgeSSSS's Avatar
Default Re: Bulb replacement in rear bumper [how do I do it?]
C'mon. Someone's got to know.
Old 06-02-2006, 04:42 AM
GeorgeSSSS's Avatar
Bump.
One last try.
Old 06-02-2006, 05:13 AM
I have never crawled under an 05 to see. I would think it would be somewhat easy though? If still under warranty let the dealer do it
If I get some time tomorrow I will run by my friends and check hers out.
Old 06-02-2006, 05:44 AM
Motohead's Avatar
Motohead Motohead is offline
just reach you hand up between the gap in the rear wheel liner and the bumper on the bottom. Turn the bulb counter clockwise and it will pop right out.
Old 06-03-2006, 12:41 AM
GeorgeSSSS's Avatar
Thanks Moto. Sometimes the obvious isn't.
Seven years of University apparently didn't prepare me for the real world.
George SSSS
Old 06-08-2006, 06:39 AM
Motohead's Avatar
See, and I never went to college...
Old 01-14-2012, 10:40 PM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
I just replaced a bulb (driver side bumper). It's helps if you remove the three tabs that hold in the plastic lining. There's one under the bumper cover and two directly behind the bumper facing the tire.
If you have Popeye arms you may want to remove the tire so the plastic lining pulls back all the way. Otherwise, have fun reaching in and feeling your way around.
Twist counter clockwise to release the bulb.
2003 Yellow H2 LUX (Sold)
Old 01-15-2012, 06:16 AM
The_Yeti's Avatar
The_Yeti The_Yeti is offline
The_Yeti is on a distinguished road
Hmmmm I thought the rear lower lights were made for a flathead screwdriver to pop in one side to get them out?
Old 02-04-2012, 06:20 AM
kacyk's Avatar
Serious? That would have been a ton easier! But I won't try that unless someone else confirms. I'd hate to brake anything.
Old 02-07-2012, 03:24 AM
The_Yeti's Avatar
Confirmed! I swapped mine out today with some led. You need a flathead screwdriver. Insert at top of lens. There's a tab there holding it in. Still going to be easier to crawl under to swap out the bulb though.
