05-31-2006, 08:26 PM
tire pressure
what do most people keep their stock wheel/tire pressure at?
under pressure tires are the leading cause of lower MPG.
05-31-2006, 08:49 PM
Re: tire pressure
I am running 45-50
05-31-2006, 08:54 PM
Re: tire pressure
38-40
'03 pewter base H2
06-01-2006, 01:09 PM
Re: tire pressure
38-40 and 45-50.... wow what a great difference between just these two!
06-01-2006, 04:54 PM
Re: tire pressure
I just put new stock BFG A/t on and I am runing them at 40 PSI.
06-01-2006, 06:42 PM
Re: tire pressure
You will loose the cushyness at 50psi  I will probably go back to running 40-45. I was just doing a mileage test going from 40psi to 50psi
06-01-2006, 06:54 PM
Re: tire pressure
and... your results of your mileage test at 50psi compared to 40-45?
06-02-2006, 05:39 PM
Re: tire pressure
OK, read the sticker on the inside door jam - drivers side. 37psi. Not 35, not 40 or higher, 37 period; for best mpg. Now, for the after market tires, we should know how/where to check for that info - correct?
06-02-2006, 05:43 PM
Re: tire pressure
idunno, I have gone back to putting my foot in it....much more fun!
06-03-2006, 11:55 PM
Re: tire pressure
The sticker on the door is more so for best ride, not best MPG. I've been running 44 in the fronts and 40 in the rears. The ride is great and I'm averaging about 14 MPG with mixed city / highway driving.
 2008 H2 Graystone Metallic
06-04-2006, 12:45 AM
Re: tire pressure
what size tires are we talking about? 35's (stock) 37's (most folks have) or 38s - 40's (a few elite have) or does it make a difference the size of tire v pressure run? Will a 38-40 ride the same with 40psi as 35? 37v35 don't seam to make much difference which pressure run with regards to ride smoothness.
06-04-2006, 02:52 AM
Re: tire pressure
37 psi
