Old 11-10-2005, 07:51 PM
md_sailor's Avatar
md_sailor is off the scale
Finally Here is the real deal! High and Low beam Conversion and it does not cost an arm and a leg. I have Done the 1400.00 Delta HID and the longest THEY went without failing was a 2 week period. the 3rd time they failed I pulled them and sent them back. This looks like the ticket and my set is in the mail.
http://www.xtralights.com/index.asp?...PROD&ProdID=2\
Technical specifications:
Bulb Type: 9007
Color & Light Output:HID Bulb Color Temperature
(Kelvin) Light Output
(Lumen)
Golden Yellow 3000K 3400 (Brightest)
Crystal White 4300K 3300
Diamond Blue 6000K 3200
Deep Blue 8000K 3100
Violet Purple 10000K 3000
Life Span: Over 3200 Hours
Voltage Range: DC 10V-16V
Rated Voltage: DC 13.2V
Rated Current: 3.2A
Output: 35W
Working Temp: -40 to 105 F
Reverse Connection Protection: Yes - No damage to ballasts & bulbs)
Short Circuit Protection: Yes - Lock protection against continuous & long-time short circuit
Open Circuit Protection: Yes - Recover when reboot, lock protection in 0.2s after open circuit
Water & Weather Proof: Yes - 100%
High Voltage Test: GND:500Vdc/1 min>10mA
Isolated Resistance: GND > 100M Ohm
Dimensional specifications:
Ballast Module: 2.75" x 2.75" x 1.25"
20" wiring harness to igniter
24" wiring harness to power source
Factory Warranty:
2 years, except 1 year for bulbs
