12-12-2002, 09:24 PM
For those who have roof lights, can you tell me how the wiring is routed from the roof into the cabin? Is there a pre-drilled hole or something?
I thought there was a discussion on this, but cannot find the thread.
Thanks.
http://www.h2sut.com
Regards,
David
H2SUT.com
Red metallic, Lux package, Poron backup sensors, throttle body by-pass, Independent dual DVDs, Volant air box, DRL mod, chrome hood handles and latch.
Thanks.
Regards,
David
H2SUT.com
12-13-2002, 01:49 AM
To clarify, I meant the externally mounted roof lights (i.e. set of 4 off road lights).
Regards,
David
H2SUT.com
12-13-2002, 01:19 PM
I talked with the accessory installer at my dealership. They routed the wuring through some hole in the driver side roof rail and down the a-pillar. Now whether they drilled that hole or it was already there with a plug in it, I unfortunately didn't ask. The light kit comes with a plug assembly that when installed sits just outside the driver side rail and will thus allow it to be removed and reinstalled as much as you like. The rail has to be moved all the way to the rear of the veicle where there is a bracket that is part of the driver rail which you take off to allow removal. Looks pretty easy, from what he did to show me.
12-13-2002, 01:39 PM
I don't have the lights, but I did look at another H2 that did. The wiring comes out from under the driver's side clearance light.
Klaus
12-13-2002, 02:47 PM
For doing the research.
Regards,
David
H2SUT.com
