Old 06-06-2006, 03:13 AM
Aubs's Avatar
Aubs Aubs is offline
Aubs is off the scale
Default Won't move
I was off-road today, and I was trying to back up over what seemed like a not-so-big birm, and the car just wouldn't go. I had the pedal pushed about halfway down, and was in 4HI Locked. I tried it many times with the same result. So I just turned around another way. But I figured I would at least generate some wheelspin or something. Is this normal?
~2005 Stealth Gray H2 SUV.
Old 06-06-2006, 04:01 AM
Default Re: Won't move
Did you try 4 lo lock?
Old 06-06-2006, 05:12 AM
Aubs, you are not normal.
I meant: that is not normal.
If it was big enough, it will stop you without letting the truck move over it...if that's what you meant. 4LOW would take care of that.
But if you just weren't moving in Reverse in 4HIGH lock, not normal.
Old 06-06-2006, 05:47 AM
Aubs's Avatar
I was actually moving in 4HI Lock reverse, but when I'd come to this birm, I would start to go up and my momentum would run out. Then I couldn't go any farther up. I didn't try 4LO Lock. I should have I guess. I just figured the car would go up, or have some spin.
And thank you for reminding me that it's time for my meds...
