Old 06-11-2006, 03:12 PM
FatBoyJim FatBoyJim is offline
FatBoyJim is on a distinguished road
Unhappy water leak
I have a 2004 h2 hummer and the drivers side floor is soaking wet, is their any drains, that might be clogged, any one HELP
Old 06-11-2006, 04:10 PM
Default Re: water leak
http://www.elcovaforums.com/forums/s...?searchid=5893
http://www.elcovaforums.com/forums/s...?searchid=5894
Old 06-11-2006, 08:12 PM
Ram S.O.S Ram S.O.S is offline
Ram S.O.S is on a distinguished road
I had the exact same problem on my 05 and the dealer fixed it on the warranty, they said it was a sunroof seal leak and it took them a couple days to fix it.
Old 06-12-2006, 02:56 AM
VTSTOMPER is off the scale
I had a water problem - mine was the doors, where the wire harness from the frame goes into the doors. Some people have had the sun roof drains, and the marker lights, I did everything else to find it was the door grommets.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 09-22-2007, 10:46 PM
Takecover Takecover is offline
Takecover is on a distinguished road
Anyone have any ideas, I have the same exact problem, for some reason the two links above do not work.
Jimmy
Old 09-22-2007, 11:36 PM
tower's Avatar
tower tower is offline
It could also be leaking from the cab (corner marker)light above the driver. This is very common (especially with roof lights or other roof accessories wired through there. Remove the light and inspect the black rubber gromet with the wires running through it in the body for integrity and placement. If necessary, seal with your favorite goo (eg). When this gromet leaks, water runs down your A pillar and collects on the floor.
Old 09-23-2007, 01:55 AM
H2BRUTE H2BRUTE is offline
Location: GAIN INFORMATION AND EDUCATION RELATING TO HUMMER H2\'S
H2BRUTE is off the scale
I had a similar leak only mine was on the passenger side. Attached is an article written by Jim Armour, son of the famous one, who worked on my H2 for quite a while trying to find the leak. The article was taken from the Ultimate Hummers Magazine, Fall of 2005 issue. Hope it helps..Da BRUTE
Old 09-24-2007, 02:11 AM
tower's Avatar
I gotta get new glasses!
Old 09-24-2007, 03:09 AM
Well, today I found at least one leak! The upper front door sill/rubber weather strip that attaches to the body and runs water down the A-pillar was loose allowing all that water to run down from the roof into the inner door seal, and then leaked into the sill/carpet area! The spot was at the top front, there appeared to be some type of black sponge like material that had come apart and allowed all that water to come down. Hope this may help someone else out!
Jimmy
Old 09-25-2007, 11:43 AM
Hey guys. you can email that cheat sheet on water leaks to yourself and then zoom in on it for readability..Jim was a master on water leaks. Hated to see him leave Hummer..Brute
