Old 06-12-2006, 03:00 AM
mwrbunny mwrbunny is offline
mwrbunny is on a distinguished road
Default Intimidated by Engine Compartment
I just opened the engine compartment of my 2006 Hummer for the first time. I had planned on doing the coolant bypass at the throttle body....just as I had on my 2003 Suburban..
I just shut the hood and said f*** it!
Obviously, you can't work on the engine from the front, and it's a long reach from the side........I guess you need a stepladder too. Maybe I'll get used to this, but I never thought it would be so difficult to get in there.
Do H2 mechanics climb up into the engine compartment? I have new respect for the people working on their H2s!!
Old 06-12-2006, 04:14 PM
Default Re: Intimidated by Engine Compartment
intimidated?????
Old 06-12-2006, 04:29 PM
GLBLWARMR's Avatar
Be thankful for so much room in the engine compartment. There are many cars out there that have no room and leave your knuckles begging for the larger compartment.
2006 H2 w/6 inch lift.
2001 F-350 w/10 inch lift
2013 Victory Cross Country
2006 Suzuki Hayabusa
Old 06-13-2006, 01:15 AM
Nixxxster's Avatar
Nixxxster Nixxxster is offline
Nixxxster is off the scale
May I ask, what is a coolant bypass? And what does it do for the car?
05 Lux Suv
95 Ducati 916
Old 06-13-2006, 01:20 AM
Read all about it.
http://cgi.ebay.com/ebaymotors/2003-Hummer-H2-TB-Bypass-Kit-8hp-FREE-SHIP_W0QQcmdZViewItemQQcategoryZ38634QQihZ019QQite mZ8074202520QQrdZ1QQsspagenameZWDVW
Old 06-13-2006, 01:48 AM
Nixxxster's Avatar
Thank for the reply, but does it really work or help?
05 Lux Suv
95 Ducati 916
Old 06-13-2006, 01:50 AM
I have absolutely no idea. It makes sence, but idunno!
Old 06-13-2006, 02:16 AM
i would love to know if that works as advertised, it seems to good to be true
Old 06-13-2006, 04:17 AM
tomp's Avatar
tomp tomp is offline
Beware that those gains on the dyno chart also were contributed by a ported throttle body and EGR mod as noted on the dyno chart.
Old 06-13-2006, 05:11 AM
Anything to get the air temp down is a good thing. I use it even on 99 Silverado. It should in theory work. It is hard for Me to tell as I did not take a temp reading of throttle body with hot water running through it and one after.
If You are up north I would not recommend eliminating it. It helps with real cold starts.
Old 06-13-2006, 06:07 AM
Old 06-13-2006, 06:14 AM
