Old 06-22-2006, 07:07 PM
H3.007 H3.007 is offline
Default Power Extension to Dash Top
Hi All,
Has anyone ran aftermarket wires down through the dash? I see there is a cap on the drivers side over the hole that contains the sensor in the passenger side. Would this be a way of running a power extension from the top down to the bottom to connect into the das power outlet? I want to install the extensions so I can mount gear on the dash without having to hard wire everything.
Thanks!
C
