Old 06-23-2006, 03:29 AM
lvmyhmr lvmyhmr is offline
lvmyhmr is off the scale
Default Internal tie-downs
I have a 2004 H2 with the spare mounted inside. Has anyone figured out a tie-down system that is no-drill that fits on the open floor space to hook tie downs to?
I usually strap the cooler handles around the spare but everything else slides all over. Need some pictures if there are any available.
Thanks in advance
Old 06-23-2006, 03:37 AM
Default Re: Internal tie-downs
The "no drill" part is the killer. Pack your stuff tight around the cooler.
Flip the bottom cushion up, then run your strap under the back cushion around the seat supports and around the cooler. Fold seat down.
I'm going to put a few cleats on the back of our SUT's rear seats so when they're folded down, I can tie junk down.
Old 06-23-2006, 12:23 PM
Hummie2's Avatar
Hummie2 Hummie2 is offline
I used a sheet of 3/4 plywood cut to fit the back floor. Mount your tiedown rings to the plywood and use some "J" bolts to the rear seat anchors in the floor to secure the plywood.
