Old 06-25-2006, 05:42 PM
zeros zeros is offline
zeros is off the scale
Default reverse wire??
hi i am trying to find a reverse gear wire that will send a signal to the back up camera to turn on when i put it in reverse... is their anything in the front around the radio a can use or do i have to run it from the tail light in the back? thanks
Old 06-25-2006, 07:17 PM
Colby Colby is offline
Colby is off the scale
Default Re: reverse wire??
Light green wire in the driver footwell fuse/relay panel. Just did the same thing two nights ago!
Colby
Old 06-25-2006, 07:23 PM
great thanks that saves me alote of time... thanks again!
Old 06-25-2006, 08:14 PM
i think i have the correct wire... would you happen to have a pic of the correct wire?
thanks
Old 06-25-2006, 09:17 PM
never mind .. i found the correct wire... thanks again.. works great!
