Old 06-29-2006, 08:31 PM
knights knights is offline
knights is on a distinguished road
Default H3 install locations help
looking at putting a JL 500/1 in my h3 can it be put behind the rear pannel were the monsoon sub is once removed? or does anyone know a better spot where it can be put so its out of sight and wont be in the way when i take the box out and put gear in
thx a ton
Old 06-29-2006, 08:53 PM
Default Re: H3 install locations help
If you are going with a box you could just mount the amp to it. Otherwise you should be able to put it in the side where the monsoon sub is when removed. That is what Bparker did on his.
Old 06-30-2006, 03:07 AM
Mark805's Avatar
Mark805 Mark805 is offline
Mark805 is off the scale
I intalled the amp for the sub where the old sub was.. then had 2 8" subs build into a box where the jack goes in the back door.
SOunds great that way and nothing in the way
08 H3 ALPHA Carbon Black
Dear GM: PLEASE SELL ME AN HX
Old 06-30-2006, 04:58 AM
good to know cant wait for the 2007 h3x to arrive =) where did u place the Z1 reciver for the GPS ?
Old 06-30-2006, 02:15 PM
Hey Mark, got any pic of the install?
Old 07-05-2006, 11:25 PM
if i remove that monsoon amp/sub will i lose the onstar and other features even if i use the onstar and chime. a GM licanced installer said that it would happend, altho i have no intention of paying there rates, still like to conferm it be in the 2007 h3x i have on order but im assuming its the same system he said it be onstar 6.1
