Old 08-30-2005, 12:12 AM
Yetti Yetti is offline
Hi guys while I was changing the oil on my H2 I noticed the air bag pedestals had a lot of grime on them, even a few small stones. so I took out the o'l windex and washed them down while the suspension was hanging. cleaned all the crud off the bags as far up as I could reach. seems the right side had more on it cause its not gaurded from splash like the left side(fuel tank is in the way). anybody ever do this to keep them in good shape?
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Yetti
www.wegotmud.com
www.glfwda.org
Old 08-30-2005, 12:14 AM
VTSTOMPER is off the scale
I never even thought of it...I wonder how bad mine are, and if it matters. Toss some armor all on there!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 08-30-2005, 12:16 AM
the one thing to consider while cleaning the bags. if its going to leave a residue DON"T use it! the bags should stay clean and dry, and not pick up any dirt.
Yetti
www.wegotmud.com
www.glfwda.org
Old 08-30-2005, 12:20 AM
Yeah, I was being a smart butt on the whole armor all. If anything I guess I would wipe them with water and a cloth.
Old 08-30-2005, 12:23 AM
Can you clean my bag?
Old 08-30-2005, 12:27 AM
Don't go there...
Yetti
www.wegotmud.com
www.glfwda.org
Old 08-30-2005, 12:29 AM
Rubiconman Rubiconman is offline
Rubiconman is off the scale
My bag gets.....nasty
Rubicons Rule, Hummers drool...and Suzuki\'s are cool too
Old 08-30-2005, 12:33 AM
Can you clean my bag? </div></BLOCKQUOTE>
Why, does your bag need cleaning? </div></BLOCKQUOTE>
It can always use a touch up.
Old 08-30-2005, 12:58 AM
Induction Concepts Induction Concepts is offline
Induction Concepts is off the scale
One piece of information. I haven't seen the airbag setup up close, so I'm not sure how its designed, but if there is nothing to stop the travel of the suspension at full droop, except the bags, for instance if the shock travel is longer than the bag travel, it can put a great deal of stress on the bags and I have seen them tear small holes, not large enough to see, but large enough to cause a leak, at the point where they mate to the top airbag plate.
Again, if there is something, like a shock or other component that keeps the suspension from hanging all its weight on the bags at full droop, then its a non-issue, but if not, try not to let all of that weight hang on the bags for an extended period of time, like overnight on jackstands. Short periods aren't bad. I used to take blocks or a jack and put under the tires to apply a little pressure/support, where the suspension could still droop if needed, but not have all of the weight hanging on the bags.
Rad Craig,
Induction Concepts
High Performance, Twin Turbo Systems
Old 08-30-2005, 05:02 AM
Orbital H2's Avatar
Orbital H2 is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">who cleans there bags? </div></BLOCKQUOTE>
There or Their, learn your Fn english
Old 08-30-2005, 10:04 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Orbital H2:
There or Their, learn your Fn english </div></BLOCKQUOTE>
It's Yetti. Give him a break.
Old 08-30-2005, 11:16 PM
Orbital H2's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">It's Yetti. Give him a break. </div></BLOCKQUOTE>
It is a major pet pieve of mine, the comment was more of a general comment.I read a lot of technical documentation and when the wrong word is used it irritates the living **** out of me kind of like finger nails on a chalk board...
how many time have you seen "your" instead of "you're"? and "there" instead of "their", "are" vs "our".
ok I will get off of my f'n soap box
Old 08-30-2005, 11:23 PM
ok I will get off of my f'n soap box. </div></BLOCKQUOTE>
Kettle meet pot. FYI, it's peeve.
Old 08-30-2005, 11:36 PM
<span class="ev_code_RED">how many time have you seen</span> </div></BLOCKQUOTE>
Kettle meet pot. FYI, it's peeve. </div></BLOCKQUOTE>
Give him a break DRTY, he's Asian.
Old 08-30-2005, 11:37 PM
Orbital H2's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Kettle meet pot. FYI, it's peeve. </div></BLOCKQUOTE>
Got me.....
Old 08-30-2005, 11:39 PM
Orbital H2's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Give him a break DRTY, he's Asian. </div></BLOCKQUOTE>
No, I am German
Old 08-30-2005, 11:45 PM
Orbital H2's Avatar
I guess I will be the guest of honor at this roasting
