Old 07-01-2006, 03:14 PM
oneworld oneworld is offline
oneworld is off the scale
Default Monsoon Blowout
Well I have 13789 miles on my H3 with no problems until today. Started my truck and a sound like a lowpitched sirein came blasting out of the monsoon speaker drivers side rear panel. The sound lasted only 30 seconds. If I use the stereo system the sound contiunes constant. If I leave the stereo off then every now and then it will just blast the sound for sevral seconds. Every time I start the truck it sounds????????
Today is Saturday the dealers service department is closed, so I have to live with this sound for the whole weekend. Well actually I checked the manual and removed fuse #38 to the amp and that kills the sound and the system.
Also I get a small amount of water in the top of my sunroof after it rains, and it leaks, but never when driving only after sitting still in the rain, then you go some place and about two onces of water slide forward onto the passenger > then its stops. Weird that it does not leak when driving.
Has anyone else had a problem with the monsoon system.
lux/offroad/sunroof/grey/nobling>drive it like you stole it
