Old 07-02-2006, 12:18 AM
rrboy rrboy is offline
rrboy is off the scale
Default fabtech tierods!!
Just installed them 2 days ago, and so far so good. I must say they are physically very heavy duty. My question is what size cresant wrench do you think I will need to get a 2 inch size nut or the size that will fit the center link side of the tierod? I want to get one to keep in the hummer toolbox. Thanks. I cant wait to go try em out.
Old 07-02-2006, 12:28 AM
MDimitri's Avatar
MDimitri MDimitri is offline
Default Re: fabtech tierods!!
I am also getting a pair soon, were they hard to install?
Old 07-02-2006, 05:02 PM
The Fabtech HD tierods are one of the best upgrades(other than HID headlights) that you can make on the H2.
Here are some crescent wrenches.
Old 07-02-2006, 10:11 PM
actually they were not very hard to install. Its more work jacking up the rig and taking the tires off then R and R the tierods. I had to borrow a friends 2 inch wrench to be able to reinstall the tierod though. I am glad I did it because these babies are heavy duty.
Old 07-03-2006, 05:14 PM
Originally Posted by PhilD
Yup, pretty easy, may need a bit of brute force here and there, but very simple install.
That's why you make sure Adam is with you. He's such a brute.
Old 07-03-2006, 05:51 PM
Desert Dan's Avatar
Do you know if they make tie rod for an H3??
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 07-03-2006, 07:16 PM
Fabtech don't. I'm sure someone will at some point, in the meantime you could easily knock up some sort of sleeve that would help.
It doesn't seem to be as much of a problem on the H3's. Only a couple reports of people breaking them so far.
Old 07-03-2006, 07:20 PM
Originally Posted by Alec W
Because the diffs tend to give before the tie-rods
Yeah yeah
Old 07-03-2006, 07:25 PM
X2 You could have a local shop handle sleeving them for you.
