Old 07-03-2006, 07:08 PM
MisterE MisterE is offline
MisterE is an unknown quantity at this point
Default Side Slope Measuring Device?
Hi All,
I'm a novice to 4 Wheeling, as I've said in my other threads most of my other threads my off-roading has been in Dune Buggies which had a super low center of gravity and extra wide wheel base. Well I'm very happy with my H3 but it is BIG change! I know that manual says it can handle a 40% side slope and I am getting ready to go back up to the Sand Dunes. Is there anything out there (other than the good old eyeball test) that you can add to your HUMMER that lets you know when your getting into the danger zone as far as the side slope?
Sorry for the newbie question!
Old 07-03-2006, 07:13 PM
westhillsat's Avatar
Default Re: Side Slope Measuring Device?
You can get a tilt meter from Trail Duty
There is a link to Trail Duty in the thread below
http://www.elcovaforums.com/forums/s...ighlight=meter
Here is a direct link
http://www.trailduty.com/products/tr...tiltmeter.html
PhilD a member here is with Trail Duty.
Old 07-03-2006, 08:21 PM
thedieter's Avatar
thedieter thedieter is offline
thedieter is off the scale
If I got one I would put a mark at 22 degrees to indicate the 40% rating of the H3.
Best regards, Happy Jack
Base Yellow H3 (Poppy)/Ebony cloth, Chrome step rail & mirrors, Auto, Sunroof, Side airbags, We Love it! Night is a Right
Old 07-03-2006, 08:23 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
any hardware store has "angle locators" for pretty cheap...
-Brian
http://www.hummerguy.net
Old 07-03-2006, 09:48 PM
DWPC DWPC is offline
DWPC is an unknown quantity at this point
You can buy a small accurate clinometer at a boating supply store for $10 or so. But clinometers made for boats don't look so hot in vehicles and you'll have to be creative mounting it. The ones for sold for 4x4s showing both lateral angle and incline are usually so small and graduated so coarsely that they don't tell you anything useful. Make sure its dampened or it'll bounce around so much it'll be useless.
IIRC, few months back someone posted a pretty slick one here on the H3 forum that they designed and installed , but I don't remember who!
And I assume you know 40% is a little under 22 degrees.
This outfit makes them for the construction equipment: http://www.tiltmeter.com/page9.html
Here's one for the truly paranoid: http://www.tiltmeter.com/page25.html
'06 H3 Adventure (9/2005-1/2013)
Old 07-03-2006, 10:39 PM
From must a couple of days ago:
http://www.elcovaforums.com/forums/s...ht=west+marine
Old 07-03-2006, 11:49 PM
just stick one of these somewhere
Old 07-04-2006, 12:50 AM
Sweet Thanks Guys!
Ahh my math sucks...How do you get 22 degrees from 40%? Just curious should I ever need to figure it out for another vehicle.
Old 07-04-2006, 01:03 AM
dont know about that math but have had my levogauge to between 36-38 degrees , scary but not even close to max truck was super stable
Old 07-04-2006, 03:25 AM
Yeah, I would think that it would be able to go more than 22°. As I said my math sucks that was why I wanted to know how to figure it out but a 40% slope at first I would have figured 90° a 100% side slope and 50% or 45° half, then knock another ten percent off that. I was suprised to hear only 22°.
But as I said my math sucks and I totally defer to you guys as the last thing I would trust to my math would be my H3!
Thanks Guys \ Gals!
Old 07-04-2006, 04:33 AM
thedieter's Avatar
The slope % comes from the amount of rise divided by the run.
Example: 1000 ft. rise divided by 3000 ft. run = .60 or 60%
This is the way roads are listed on grade signs.
They use the same method for side slope. 4/10 = .40 or 40%
Calculating the angle gives 21.80 degrees.
The gage must be mounted vertically to be accurate.
Old 07-04-2006, 04:54 AM
Wow, now I am totally lost, when I do it I get 33% for you example for the rise \ run example.
I am guessing the mounting behind the review mirror is a good place so that it reads 0? on level ground.
Sorry for being so dense, like I said I trust the numbers you guys are giving me I just wish I could understand how you get them so I didn't feel so stupid!
Old 07-04-2006, 05:10 AM
thedieter's Avatar
It would be 1/3 = .33 or 33%
You could think of it in terms of the width of the H3, about 6 ft.:
2 ft. higher on one side gives 2/6 = .33 or 33% Hope there are no bumps.
The gage that Neo shows appears to be stuck on the windshield at an angle which induces an error.
Old 07-04-2006, 03:15 PM
Is this a good link for the math for our application?
http://draco.acs.uci.edu/rbfaq/FAQ/9.3.html
Old 07-04-2006, 03:37 PM
read thru this thread also , lots of good stuff
http://www.elcovaforums.com/forums/s...ad.php?t=15039
Old 07-04-2006, 04:04 PM
good rule of thumb;
if the door handle is touching the ground, the slope is too much
Old 07-04-2006, 04:06 PM
Originally Posted by Agriv8r
good rule of thumb;
LMAO thats when i back off too
Old 07-04-2006, 04:07 PM
Old 07-10-2006, 09:31 PM
Hey All,
I just got the same gage as Neo. If it is stuck at an angle how much error will it induce? I'm looking for the gauge to tell me if I am getting in the danger zone but I'm not going to be staring at it for an exact measurement. Will the angle make it useless or are we talking a degree or two off, which would be fine. As I said I'm just looking for when I've entered the ballpark of being stupid!
Old 07-10-2006, 09:54 PM
thedieter's Avatar
I am going to have to defer to the experienced wheelers since my only experience is from growing up driving on washboard roads.
I have been following this useful Forum to learn what the H3 is capable of.
You could check how much error is induced by putting the gage at different angles and see what the difference is between having the gage face verticle and at an angle at which you are planning to mount it. It looks like the gage has a ball for the indication so it won't suffer from friction.
I don't know when one gets to the stupid point but the door handle dragging may be it. If nothing is dragging, I can't see a problem.
