Old 07-05-2006, 04:00 PM
humdoug's Avatar
humdoug humdoug is offline
humdoug is an unknown quantity at this point
Default Front end lift
I did the torsion bar adjustment and still not completely satified with the front end lift. 2 1/2 turns and the front is still a bit raked. I wanted to go 3 or 3 1/2 but most posts indicate future problems.
Has anyone turned 3 or 3 1/2 without problems?
Has anyone installed a lift kit and satified with the results? If so let me know which kit you used.
Old 07-06-2006, 12:19 AM
Default Re: Front end lift
I'm at three now. Started at 2.5. It rides different from stock, but I think it is worth it
Old 07-06-2006, 04:56 AM
blindzebra's Avatar
i have 3 turns done to mine. That raised the frond end about an inch. I asked the dealer how much would be the max and he said 1.5 is about all one could safely do with no upcoming damage. Not to mention, it's still under waranty. Do it. Do it.
Old 07-06-2006, 04:15 PM
H3.007 H3.007 is offline
Has anyone avoided the torsion bar adjustment and instead purchased a true front end lift to even out the front and rear? Does anyone have a suggestion for a cost-effective but quality kit?
Thx,
Chris
Old 07-06-2006, 10:03 PM
blindzebra's Avatar
yeah for looks it's great, but for ride on and off road it's (insert pukie face here)
Old 07-06-2006, 11:13 PM
This works best for the front end lift:
Old 07-07-2006, 12:48 AM
ballistic nylon for sure...
Old 07-07-2006, 01:50 AM
2 ply.
