Old 07-07-2006, 08:52 PM
Donald Smith Donald Smith is offline
Donald Smith is off the scale
Default Tail Light
Read ownwers manual to remove tailight housing-it says remove two screws and gently remove from alignment pins. Its loose-
but then I pull, wiggle or whatever it going to break if I don't get some guidance here.
TIA
Don
Old 07-07-2006, 09:00 PM
Default Re: Tail Light
Gently is not the right word. Just pull on the light, it'll pop out of there.
Old 07-07-2006, 10:11 PM
humma_H3's Avatar
humma_H3 humma_H3 is offline
humma_H3 is on a distinguished road
it will pop loose right before you expect it to shatter into a million pieces... ya, gently is no where near the amount of force needed. if you think you are going to break it- take it to the dealer, let them bust it.
matt
cincy
matt
cincy,oh
LOCKERS RULE!! Open Diffs DROOL!!!
2006 Black Hummer H3
Old 07-07-2006, 11:14 PM
Thanks,Next question-what are the color codes for tail, brake/turn. I am wiring in diodes so I can tow the Hummer.
TIA
Don
