Old 07-11-2006, 03:34 AM
tomp's Avatar
tomp tomp is offline
Default How many feet 3/8" Syn cable will spool up on 9500 winch?
Will 125' 3/8" synthetic cable fit on a Warn 9500 winch?
Old 07-11-2006, 03:36 AM
tomp's Avatar
Default Re: How many feet 3/8" Syn cable will spool up on 9500 winch?
Looks like trail duty has several different types. Whch is good for all around use with good balance in price?
Old 07-11-2006, 03:47 AM
tomp's Avatar
Thanks for you replies Phil. Guess you figured out I was looking at all this stuff on TD
Old 07-11-2006, 04:57 AM
2-H2's's Avatar
2-H2's 2-H2's is offline
Originally Posted by PhilD
There did seem to be a common theme
If you have any other questions just email/Pm me.
Not only will he sell it to you...then he'll rub it in & make you use it to pull XXL out of the creek
Old 07-11-2006, 12:43 PM
tomp's Avatar
Might opt for strongest cable then, huh?
Old 07-11-2006, 01:46 PM
In theory, you want as little line wrapped on the drum as is practical, given that you will have at least 25ft or so out nearly every time you winch.
Reason being, the strength of the winch is when the line is down to the last row of wraps on the drum. Every row of wraps above the first lessens the pull power of the winch. So if you stuff 125ft on there and don't really use it that much, you would effectively be working the winch harder than if you had a 100ft line doing the same work. Getting the line extension is the best route.
Old 07-11-2006, 04:03 PM
tomp's Avatar
nicely put...makes perfect sense. Thx...
Old 07-15-2006, 02:49 AM
GeorgeSSSS's Avatar
GeorgeSSSS is off the scale
Just to put a footnote on Paragon's excellent explanation, you can use a snatch block to double the amount of line you are using for a short range pull and thereby increase the power of the winch. In this way, you can have the flexibility of having the longer amount of line on the winch, but still have the power of having purchased a shorter length.
George SSSS
