Old 07-12-2006, 07:31 PM
USC78 USC78 is offline
USC78 is on a distinguished road
Default Transmission Already Needs Replacing!!
I have a 2003 H2 with around 45K miles on it. During a recent trip, I had trouble getting the vehicle to shift from 1st to 2nd. It also would not go into 4th gear. The dealership tells me that the "2 / 4 Band" is burnt. They recommend replacing the transmission at the cost of $3K! While my regular warranty has expired, I was hoping that it would be covered elsewhere (e.g., 100K mile powertrain warranty, etc.) The dealership says no. Any input would be helpful.
Old 07-12-2006, 10:55 PM
HummBob's Avatar
HummBob HummBob is offline
Default Re: Transmission Already Needs Replacing!!
Isn't this a COMMON problem? I kinda remember reading some posts on this?? If it is a KNOWN problem, shouldn't it be fixed Anyways for FREE?
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 07-12-2006, 11:17 PM
Racer-X's Avatar
Racer-X Racer-X is offline
Racer-X is off the scale
So if you have an extended warranty why would it not be covered?
BTW - my 03 has had 2 new transmissions - for a different failure though.
Old 07-12-2006, 11:18 PM
Racer-X's Avatar
BTW 3K is robbery - call around if you end up paying for it.
Old 07-13-2006, 12:51 AM
Some of this may help.
http://www.elcovaforums.com/forums/showthread.php?t=14417&highlight=transmission+fail ure
http://www.elcovaforums.com/forums/showthread.php?t=12606&highlight=transmission+fail ure
http://www.elcovaforums.com/forums/showthread.php?t=9995&highlight=transmission+failu re
http://www.elcovaforums.com/forums/showthread.php?t=12530&highlight=transmission+fail ure
TSB:
http://www.elcovaforums.com/forums/showthread.php?t=5641&highlight=transmission+failu re
Old 07-13-2006, 04:18 AM
KenP - Thanks for all the input.
Old 07-13-2006, 05:51 AM
Ken, you are the Search Master. How do you do that again?
Since I don't really know Jack about crap, I've had to adapt by learning the in's and out's of the Search function. Besides, I don't want to read through all that stuff again.
Go ahead, ask something....
I hope you find something to help you out.
Old 07-15-2006, 02:49 AM
cmd's Avatar
cmd cmd is offline
cmd is on a distinguished road
I am on vacation in Florida 1500miles from home and the transmission was just diagnosed as bad clutches? something to the effect of not changing at the corarect prnessures?any chance at 46900mi the dealer will help me out back home? the engine also has a noisy crank bearing,, this is not acceptable that there is no recall on the transmission, i know of 3 people locally that have had the same problem, Any one have any ammo to go to the dealer with for out of warranty situations like this.
Thanks.
Old 07-15-2006, 03:09 AM
Thanks.
go buy you a power programmer and see if you can change the shift pressure and speeds and RPMs.
Also, try driving it in tow/haul mode. That will change things.
There is no reason to have a recall on the tranny, there is no "defect." It sucks that you have a problem, I am well on my way at 32K miles and about a year out of warranty, but these trannys are used in millions of other vehicles.
Old 07-18-2006, 08:55 PM
cmd's Avatar
cmd cmd is offline
Hey Paragon, are you a Hummer Mechanic? how would I know how to set this up, would a dealer do it?. The Hummer dealer i was at only work on Hummer and the mechanic was explaining that the pressures i believe were to high at which it changed up the gears.
thanks, any info will be greatly appreciated.
Old 07-18-2006, 09:26 PM
tomp's Avatar
tomp tomp is offline
Has anyone had issues like this when using high shift pressures from those modified through one of the power programmers?
Old 07-18-2006, 09:42 PM
I'm not a mechanic, but I stayed at a Holiday Inn Express last night.
The programmers alter your shift tune from stock, so it might work. On my Diablosport programmer, I can also go in and manually make adjustments to each shift point.
It's just a programmer you can buy from a local 4x4 or speed shop.
Old 07-18-2006, 09:44 PM
I have the the tune and then have the shift pressures up higher than the tune was originally.
It's not going to harm the transmission. In fact, in theory, it should be better on the transmission, but it would be harder on the parts down the line.
