Old 07-16-2006, 04:14 AM
Field Rat's Avatar
Field Rat Field Rat is offline
Field Rat is off the scale
Default Rattle/Squeaking from Front Interior
I have recently been getting a serious rattle/sqeaking noise coming from somewhere in the front driver's side door area below the A-pillar and dash. I can't tell where it is coming from because I have to be driving to hear it. Anyone had this problem?
\'97 H1 Green Soft Top SOLD
\'03 H2 Pewter SUV= SOLD
\'05 H2 Desert Sand SUV
\'05 H2 Stealth Gray SUV
Old 07-16-2006, 06:20 PM
H2Finally's Avatar
Default Re: Rattle/Squeaking from Front Interior
The a/c vent/trim piece where u described the noise coming from, has a friction tape at the back of it. Perhaps this tape is missing or damaged in yours. Easy enough to check, remove the bolts, pull straight towards you.
If not, could very well be the outside windshield seal problem -- which noise always sounded somewhere inside the cabin.
Can BLING Get You Home?
Old 07-17-2006, 09:24 PM
DeBest DeBest is offline
DeBest is off the scale
I have been experiencing the same rattle that you are describing. I would like to hear from anyone who has solved the problem!!!
Hummafied
06 White H2
00 AMG Mercedes
00 Harley Fatboy
65 Harley Panhead
