Old 07-20-2006, 12:21 AM
Default Weird noise in cargo area
Just started this afternoon. Sounds kinda like rubber on rubber or rubber on plastic. Usually only when I brake hard or go over a bump.
Old 07-20-2006, 12:43 AM
Default Re: Weird noise in cargo area
Luggage area, or could it be from one of the rear doors? I had the Styrofoam type squeaking on my Utah trip over rough roads.
Old 07-20-2006, 12:44 AM
Does it have a weird odor????
Old 07-20-2006, 12:51 AM
Are you asking if the noise has an odor?
Old 07-20-2006, 01:08 AM
I thought you said nose....sorry
Old 07-20-2006, 01:19 AM
check that spare tire is tight and check jack compartment . if nothing found crank the tunes
did you have sex in the back ? you probably busted the suspension
Old 07-20-2006, 01:30 AM
Not likely, I think he's on a dry spell
Old 07-20-2006, 03:26 AM
LittleBear's Avatar
LittleBear LittleBear is offline
LittleBear is on a distinguished road
Crank the tunes??? Sounds familiar.
Old 07-20-2006, 04:30 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
ohhhh, that's cold...
Old 07-20-2006, 05:26 AM
deserth3's Avatar
deserth3 deserth3 is offline
Put the mother-in-law on the roof!!
Old 07-20-2006, 05:35 AM
Idaho-Hummer's Avatar
Idaho-Hummer is off the scale
she would do some damage to the H3 and blow out the tires
Old 07-20-2006, 05:57 AM
evldave's Avatar
Originally Posted by Sewie
...Sounds kinda like rubber on rubber or rubber on plastic. Usually only when I am hard or go over a hump.
I know what rubber on rubber on plastic sounds like, but not rubber on rubber on rubber on plastic. Sorry I couldn't help!
Old 07-20-2006, 05:59 AM
Old 07-20-2006, 06:00 AM
Such dirty minds on this forum.
Old 07-20-2006, 06:35 AM
Old 07-20-2006, 06:53 AM
westhillsat's Avatar
someone rubbed some rubbers and now there's an odor??
Old 07-20-2006, 06:58 AM
rubbery smelling noise?
S.
Old 07-20-2006, 07:00 AM
Well you guys obviously aren't any help.
I'm going to the dealership tomorrow anyways. Maybe they can figure it out.
Old 07-20-2006, 07:04 AM
I know I know.
I have the same thing.
It is rubber on plastic.
Check the side compartment in the back on the PSSD. Tose two little rubber things on top that hold the door closed. Tighten them up. Do the same on the compartment foor to where your jack is.
It worked for ours.
Old 07-20-2006, 05:33 PM
Well I just dropped it off at the dealership. I'll let you guys know what they find.
F5 and Timgco, thanks for the ideas.
