Old 12-17-2005, 06:59 AM
Christian GM Christian GM is offline
Christian GM is off the scale
Hi guys,
I've looking about more info on bi xenon lights for both H2 and H3, I'm looking for a replacement headlamp kit with xenon low beam and xenon or alogen high beam.
The point is about an Hella kit, I had search more info on Hella website w/o found it.
I'm looking for Hella kit because Hella is German and maybe their kit have also European homologation...
Some one of you have installed some European xenon kit?
Any suggest will be appreciated!
Thanks!
Hi guys,
Thanks!
Old 12-18-2005, 01:43 PM
Beastmaster's Avatar
Beastmaster is off the scale
The only known projector kit is the Sylvania XE7 projectors. I don't know if they have an ECE code number on them. I do know they are DOT certified.
You might be able to retrofit a Hella, but you would need to fabricate a retaining ring around the projector for mounting.
M101A2 Trailer
Old 12-18-2005, 06:51 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Beastmaster:
You might be able to retrofit a Hella, but you would need to fabricate a retaining ring around the projector for mounting. </div></BLOCKQUOTE>
Link?
Old 12-19-2005, 01:54 AM
For the XE7?
http://www.xesighting.com/
http://www.brightheadlights-hid.com/
M101A2 Trailer
