Old 07-21-2006, 08:27 PM
twenty2's Avatar
twenty2 twenty2 is offline
Default leaky!
I just got into my truck only to find water on my dash!! It's coming from my plastic covering for where my garage door controls and my speaker and my 2 lights are from. I'm guessing the leak is coming from my roof where the cab lights are at??? Anyone else ever have this problem???
Old 07-21-2006, 08:58 PM
Default Re: leaky!
Roof marker lights, Had the same issue both front and rear. Dealer replaced all the marker lights and no more leaks.
Old 07-24-2006, 10:53 PM
twenty2's Avatar
Default Re: leaky!
Okay fixed... Now... I was just vaccuming my floor, and under the floor mat on the drivers side, I noticed that my floor was wet!! No other issues anywhere else???? There was a pretty bad rain storm here just about a week ago in which I was plowing through some big puddles... But, I didn't see any leaks going through my firewall or my door? AHHHHHHHHHHHHHHHHHH.... help needed
Old 07-24-2006, 11:06 PM
ShortBus's Avatar
ShortBus ShortBus is offline
ShortBus is off the scale
Default Re: leaky!
I just had the front ones fixed, where should I look for leaking in the rear? Is it as obvious as the front?
Old 07-24-2006, 11:36 PM
Big Z Big Z is offline
Default Re: leaky!
Dry out good, leak check again--hose it awhile!--and check. Most Likely the same problem, bet ran down the A piller.
Old 07-25-2006, 04:05 AM
Default Re: leaky!
On the rear ones leaking, it was letting the water run down the center section of the window on the inside.
