07-22-2006, 01:46 AM
under what kind of condition to lock the rear differential?
On the adventure H3, what is the rule of thumb to use that feature ??
07-22-2006, 01:54 AM
Re: under what kind of condition to lock the rear differential?
any questions?
matt
cincy
matt
cincy,oh
LOCKERS RULE!! Open Diffs DROOL!!!
2006 Black Hummer H3
07-22-2006, 02:16 AM
07-22-2006, 03:20 AM
Anytime I use 4 low
07-22-2006, 03:47 AM
thanks dude, it is a hell of a climb...
07-22-2006, 03:52 AM
i leave mine unlocked most of the time , after a while you get to know when you will need it . just try getting up the obstacle without rear locked , if you start to get some wheel spin push the locker button , truck will usually crawl right up . the next step if still having trouble is BTM , apply the brakes while giving it gas slowly let up on brake till truck starts moving keep that tension on your brake until clearing the obstacle let off brake and unlock rear till next obstacle . leaving the rear locked for long periods can build up heat . think of it as a "use as needed" feature  we dont recommend doing this without one
07-22-2006, 03:54 AM
and really need it when 3 wheelin
07-22-2006, 04:40 AM
Holy ****...!!!
07-22-2006, 05:29 AM
thanks for the info..are all the H3 going up there ok, look like it is more than a 45 degree angle going up..wonder how is look like when going down..
07-22-2006, 05:37 AM
07-22-2006, 02:30 PM
07-22-2006, 03:13 PM
Yeah; that's a long way to drive with your eyes closed!!
07-22-2006, 08:23 PM
it sure is man  you should try to make it over next month
07-24-2006, 03:16 AM
Where you guys in 4Lo and 1st gear going up and down?? Using bakes down??
Mercedes-benz Technician
07-24-2006, 03:36 AM
also when you guy going downhill, are u using the handbrake ? or just the locker..
07-24-2006, 04:10 AM
just use the foot brake ( regular brakes ) for BTM and going down . put shifter in 1st for going down and you hardly need to use the brakes . i used my brakes only 3 or 4 times coming down lions 1st is really low . dont really need the locker for going down , but have heard it helps slow you even more , i cant tell a difference .
