Old 07-26-2006, 02:11 PM
backache backache is offline
backache is on a distinguished road
Default Lift Question
Has anyone found or using a suspension lift smaller than 4" using rear air?
Old 07-26-2006, 06:36 PM
Default Re: Lift Question
Thanks for the info.
Old 07-26-2006, 11:42 PM
tomp's Avatar
tomp tomp is offline
I saw some new torsion bars available that "claim" to allow you to raise the front up and not increase firmness.
Old 07-26-2006, 11:43 PM
tomp's Avatar
http://www.performanceproducts.com/P...&vehicle=30349
Old 07-27-2006, 04:24 AM
From what I am hearing the best route to go with a more traditional lift, 4" rancho or something similar to keep everything working properly without any premature wear.
For those of you who have done this are there any regrets, and what was your over height increase after tires?
What size wheels and tires are you running?
Thanks for all the info. I am trying to decide if the is a good choice.
Old 07-27-2006, 06:08 AM
tomp's Avatar
agreed Phil
Originally Posted by PhilD
Yes, I know someone who runs them and says they are pretty good. But you still have the issues with steering/driveline premature wear.
You can do it, but there are trade-offs.
Most of the "kits" are just + keys and they will increase ride firmness.
Old 07-27-2006, 09:17 PM
tomp's Avatar
Phil, I cranked mine only 4 turns (.8") and the ride feels much stiffer. At this small amount, am I at a high risk for these premature component failures?
I have 35 tires that are 13.5" wide.
With this setup, would the Cognito system be a good idea?
I am considering dropping the TBs 1.5 turns and adding the Cognito stuff....
