Old 07-27-2006, 07:13 PM
GotSandH3's Avatar
GotSandH3 GotSandH3 is offline
GotSandH3 is off the scale
Default Dual Antenna CB Radio
I remeber seeing a pic up here a while ago with someones rig that had dual antennas. I did a search but couldnt find the pix. Has anyone done this before?? I have two 4 ft antennas that i need mounted somewhere. Anyone have any advise on where to put them? I was thinking mounting them on the spare tire. Pictures would be great. Thanks
Mercedes-benz Technician
Old 07-27-2006, 07:38 PM
Vettster Vettster is offline
Default Re: Dual Antenna CB Radio
Check out a truck stop. You should be able to find antenna mounts in almost any of the larger ones like Flying J.
Old 07-27-2006, 08:06 PM
ree's Avatar
ree ree is offline
What and then steal them and install them on his 3?
GotSandH3
Are you remembering an H2 or H3 with dual antennas. Several H2'ers have duals. Alec W and H2 Rocks, probablty several others too.
Otherwise poke around these for mounting ideas (found them using search):
http://www.elcovaforums.com/forums/s...ad.php?t=13474
http://www.elcovaforums.com/forums/s...ead.php?t=2010
http://elcova.com/groupee/forums/a/t...1/m/6391091241
http://www.elcovaforums.com/forums/s...ead.php?t=2940
If you don't see something that works, cook something up
'03 pewter base H2
Old 07-27-2006, 08:42 PM
GotSandH3's Avatar
It was on a H3. I just found who I was talking about. Its on "Green Lantern's" H3. I just havent found of a pic of how he mounted them.
Old 07-27-2006, 08:48 PM
ree's Avatar
ree ree is offline
So when I hand you the link, you don't even use it? See this link above:
I found it by, get this, reading, this thread that I found using Search, and then following the link. It shows how he mounted one of them. Looks like there's room on the other side of his bracket for both.
'03 pewter base H2
Old 07-27-2006, 10:09 PM
Not quite what I had in mind.
I think they might sell them in the truck accessories.
Old 07-27-2006, 11:00 PM
Some good reading on dual antennas. I don't know how TGL has his connected, but just slapping an extra antenna up there won't necessarily improve signal.
http://www.firestik.com/Tech_Docs/SNGL-or-Dual.htm
http://www.firestik.com/Tech_Docs/NGP_DUAL.htm
Old 07-28-2006, 01:15 AM
evldave's Avatar
evldave evldave is offline
evldave is off the scale
x2, plus if you really want to use 2 antenna's to improve reception (instead of just looking really good), have a professional tune it unless you've done it before. I had a 5' firestik on my Jeep and could never tune it right, had a CB-expert buddy of mine tune it for me and it was way better. I think it's harder to tune a twin-stick setup.
Old 09-02-2007, 07:26 PM
BigBill's Avatar
BigBill BigBill is offline
BigBill is an unknown quantity at this point
I like this idea and look much better than my original idea of mounting it on the roof. I have both a CB and a scanner. If I had two antennas side by side, would there be a problem with interference? The scanner is also a digital, trunking scanner so I can escape with ease!!
Old 09-27-2007, 04:50 PM
BigBill's Avatar
I take it this is a dead thread as no one has bothered to reply to my questions!
Does anyone have information on how to mount either a single or dual antenna setup on the rear spare tire mount?
2007 Hummer H3 Luxury/Adventure - Slate Blue Metallic; OEM Rocker Panel rails
Old 09-27-2007, 07:26 PM
Look up about 5 posts and follow the links.
Old 09-27-2007, 09:04 PM
BigBill's Avatar
Found the "hidden" link! I saw this, but was wondering if the metal band would be strong enough to hold the mount.
Old 11-22-2007, 09:40 PM
H3Eric H3Eric is offline
H3Eric is off the scale
I have dual antenna's mounted using the metal strip mounted on the spare tire bracket. It looks great although the CB reception is bad.
I had them for abut 2 1/2 years now (bought my H3 when it just came out) and the construction is trong enough. I bought the antenna's at Love's truck stop.
