Old 07-29-2006, 05:35 PM
adamid2000 adamid2000 is offline
adamid2000 is on a distinguished road
Default largest tire to fit on stock h3?
Hi Guys,
I'm new here so forgive me if I ask a dumb one, but I am looking to see what is the largest size off road tire I can git on the stock H3 (adventure package) without rubbing?
I've seen some people put 315 75 R16, but it would seem to me the these would rub a the slightest road bump, or as soon as your steered...
Am i wrong? and can someone tell me what is the largest size off road tire I can git on the H3 without rubbing?
Thanks!!!
Old 07-30-2006, 12:25 AM
Ipedog's Avatar
Ipedog Ipedog is offline
Default Re: largest tire to fit on stock h3?
You can run the 315's w/o a problem. At most they will rub on the sway bars and they will only do that if you crank the t-bars (OBTW - They will rub on 285's if you crank the t-bars too).
Rob (Ipedog - Say "Ip-E-Dog")
Black Sheep HUMMER Squadron
Old 07-30-2006, 01:29 AM
what about the fenders, under full compression, when the wheels are stuffed in the fender, will it not rip them out? and do u notice a difference front vs rear?
For example i found these:
Super Swamper LTB
Size 34x10.50-16 LT
Black Letters
Load Range E
$136.99
