Old 08-03-2006, 09:48 PM
H3 Hummer's Avatar
H3 Hummer is off the scale
Default Muffler has a hole
I noticed something dripping from underneath my H3 - it was quite dirty so I took a closer look. The drip was coming from the muffler - it is most likely condensation dripping through a hole.
I already had an appointment scheduled for next Tuesday for my oil etc. so I called them and told them. The Service Advisor told me that is normal - I said in the middle of the muffler? He said yes.
I know it is an actual hole because I can slightly feel the air coming through - what I don't know is it made to do this like he said? Upon closer review it looks like it is supposed to be there.
The area is right before the leaf springs - the muffler is expanded in this area.
Old 08-03-2006, 09:50 PM
Default Re: Muffler has a hole
Weep hole, its supposed to be there!
Old 08-03-2006, 09:54 PM
Desert Dan's Avatar
It looks like your diff has a weep hole to
The weep hole is suposed to be there to let condensation drip out.
It looks like there is a second hole in the middle of the muffler?
Looks like your H3 has seen some trail use too!!
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 08-03-2006, 11:17 PM
H3 Hummer's Avatar
Just a little :-)
Old 08-03-2006, 11:39 PM
lotus4s's Avatar
lotus4s lotus4s is offline
What's up with the wet spot on the diff, it's not leaking is it?
I just noticed I have a transfer case leak at the output shaft seal w/7k miles on the truck.
Old 08-04-2006, 12:35 AM
As everyone else says...weep hole. But, that is not a muffler, it is a resonator. Muffler is at the rear and most likely has weep hole(s) too.
Old 08-05-2006, 06:35 PM
Michael1 Michael1 is offline
Location: Northwest of Los Angeles, just outside all the traffic
Michael1 is on a distinguished road
That's also normal.
GM uses the cheapest seals they can buy. Always have.
Michael
Old 08-06-2006, 02:14 PM
Originally Posted by Michael1
That's also normal.
Michael
Sure, GM wants to purchase the cheapest seals so that their warranty costs go up....makes sense to me. By the way, the seal on the rear axle is not determined by GM, but by American Axle, the manufacture of the axle.
Only seals I have ever had that failed on a GM vehicle are drive axle seals, and they usually fail due to improper installation of the axle at the manufacturing site.
Liquid seals usually fail due to the machine at the plant being out of calibration, or running out causing a skip, and the operator allows the unit to be shipped without tagging for car final to repair before shipment.
The FJs are calling you...
Michael...
Old 08-06-2006, 06:04 PM
LMFAO!!! there you go being "Funny" again
