08-03-2006, 11:25 PM
There are 2 wheel chucks in jack compartment
Just cleaning out the jack compartment and noticed there are 2 wheel chucks under the straps.
I never noticed them before a very good idea
Also a bead of sweat(its hot) dripped on the instructions that are on the fabric and it wiped off the print ?
Why would they use ink that wipes off with water
I had a lot of stuff stored in there and Im getting replacment jack tommorow I figured they wouldnt put the stuff back in right.
Im also finally getting my roof rails replaced also
08-04-2006, 12:40 AM
Re: There are 2 wheel chucks in jack compartment
If I ever need to hide a body in the rear of my H3, I'm calling you....
08-04-2006, 05:20 AM
he has the frig TOO , if you need the body kept on ICE
08-04-2006, 06:45 AM
Had my jack replaced last week. I better take a look  to see what they put in there.
Now my Hitchcam picture is going fuzzy off and on. All the connections seem fine. They took a quick look yesterday and said it probably needs a new camera. I'll take it in Monday to have the camera swapped out.
S.
08-04-2006, 03:32 PM
I took inventory on the stuff in there.
jack board
tow strap
25 foot coil air hose
foldable shovel/pic ax
jumper cables
6 bungee cords
tire repair kit
first aid kit
1 digital air gauge
1 air gauge for air hose
few rags ( they stop any rattleing)
A little room for some small stuff left over.
Total weight = 13 lbs 5 oz
I got a 2007 suburban loaner.
It has a nice display, mpg, amount of air in tires, ect I wish the 3 had those things. the avr mpg says 11.9
I disingaged traction and put it in 2wd mode and the tires wouldnt spin.
Tryed it on a step hill a small ert.
I thought it would have more balls.
It drives nice and you can see out the rear window.
I saw that cubby thats in front of the shifter it was on a 2006.Its nice I wish I had one.
I was going to ask how much for the plastic piece at the parts department but no one was there? I will ask latter when I pick it up.I wonder if they have a ashtray for there also?
below is pic of all the stuff I stow in the jack compartment.
08-04-2006, 03:38 PM
For you old timers (which I am not), it's Fibber McGee's closet.
29-Jul-2008
08-04-2006, 03:46 PM
