Old 08-04-2006, 10:53 PM
deserth3's Avatar
deserth3 deserth3 is offline
Default BEC connector question
I'm installing lower grill lights. When I removed the BEC (Breaker and fuse modul in front of the battery) the large white and gray connector did not come up with the fuse platform.
I didn't think much of this untill I tried to reintall the relay/fuse block and it wouldn't latch into place.
The arm on each connector that is supposed to latch onto a plastic knob on the relay/fuse block was down on both connectors.
The knob for the gray connector is broken off. I found it inside the connector. After I unlatched the connectors from the base and installed them into the fuse block The fuse/relay block installed and latched without any problem.
Should I worry about this knob or get the fuse/relay block replaced ASAP.
