Old 08-10-2006, 08:06 PM
vador99 vador99 is offline
vador99 is off the scale
Default wiring=need help
Is it easy to remove the platic piece in the trunk wall ?
Where can i find some info about how to remove them?
Old 08-10-2006, 08:17 PM
BDPJR's Avatar
BDPJR BDPJR is offline
BDPJR is off the scale
Default Re: wiring=need help
What are you trying to wire? When I installed my side work lights on my roof rack I went through the rear roof lights and down to the tail lights. I drilled a few holes and RTV them when done. Easy, but when I pulled the plastic pieces that are around the rear speakers, one of the tabs broke. No big deal because there are more than one, but a lot of these tabs are good for a one time installation and if you aren't carefull then...snap!
Old 08-10-2006, 08:23 PM
ree's Avatar
ree ree is offline
Do you mean the trim over the rear wheel wheels in the rear cargo area? If so I'll dig up some trim removal diagrams instructions. It's a little more involved than you think so if you are just trying to get wires to the rear end or roof (as BDPJR) suggests, there are better ways than removing this trim. Let me know.
'03 pewter base H2
Old 08-10-2006, 11:12 PM
i just buy a traffic advisor and i want to bring to front a big wire.
Old 08-10-2006, 11:58 PM
Beastmaster's Avatar
Beastmaster is off the scale
If I understand you correctly, you got a traffic director light bar and you want to mount and wire it.
Your best bet - draw from your existing light bar wiring in the front, mount the traffic director on the back of your roof rack, and then use the same method of running the light control into the vehicle using the existing light bar run.
M101A2 Trailer
Old 08-11-2006, 02:38 AM
i think that will be that way...Is it easy to enter the wiring in the truck by the roof corner light?
