Old 08-12-2006, 08:26 AM
murf's Avatar
murf murf is offline
murf is on a distinguished road
Default 38x15.5x18 tires
would these tires fit on a hummer with no lift kit? (with aftermarket rims)
Old 08-12-2006, 03:47 PM
Screeper's Avatar
Screeper Screeper is offline
Screeper is an unknown quantity at this point
Default Re: 38x15.5x18 tires
Not even close.
Old 08-12-2006, 04:45 PM
murf's Avatar
is it the hieght or the width of the tires that won't fit, or maybe both, what size lift would i need?
Old 08-12-2006, 06:02 PM
Screeper's Avatar
Six inches of lift, and even then you might get slight rubbing in extreme situations. If you do a search for tires you will get loads of information.
Al
Old 08-12-2006, 06:38 PM
tbuckley's Avatar
tbuckley tbuckley is offline
tbuckley is on a distinguished road
For what it's worth, I'm running 38" x 13.50" Toyo M/Ts on 18" rims -- with a 4" Rancho lift... no problems. Here's some photos for reference...
http://www.elcovaforums.com/forums/a...7&d=1155008789
http://www.elcovaforums.com/forums/a...6&d=1155008703
http://www.elcovaforums.com/forums/a...8&d=1155008905
http://www.elcovaforums.com/forums/a...9&d=1155008955
I agree with Screeper though, the 38" x 15.50" is not happenin' unless you get that H2 of yours off the ground some.
Cheers!
May your glass be ever full.
May the roof over your head be always strong.
And may you be in heaven half an hour before the devil knows you're dead. ~ Irish Blessing
Old 08-12-2006, 07:15 PM
You must get a lift to run those tires. I don't think the 4" is high enough if you're going to wheel the truck on anything more than a dirt road. We have a 6" lift and still get rubbing when offroad. Most noticably on the front wheel wells where we've had to trim much of the fender lining away.
Old 08-14-2006, 02:36 PM
murf's Avatar
hey tbuckley, nice hummer
thanks to everyone taking time to answer my question. I didn't think before I ordered so I will see how bad they are. By the sounds I'll be investing in a lift kit
Old 08-14-2006, 06:08 PM
Nice Tbuck! I like it.
Old 08-20-2006, 10:44 AM
murf's Avatar
With gear rims these tires do fit, can flex the suspension without rubbing(to an extent) and only when the tires are turned all the way do they rub, but not much at all. I will try to post some pics soon.
Old 08-21-2006, 02:51 AM
mboard mboard is offline
mboard is off the scale
I have 38x13.5 Toyo MT on stock rims, however dealer put a different torsion bar in to level out front. Just a little rubbing on front torsion bar when turn reall sharp
Old 08-21-2006, 04:09 AM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
What are gear rims???
Post some pics
