Old 08-12-2006, 09:44 PM
Denny Crane Denny Crane is offline
Denny Crane is off the scale
Default AC Receiver / dryer Install Instructions
Can someone provide instructions for removing the Receiver / Dryer and the Orifice Tube.
I've replaced the compressor so only thing left are these parts.
For what it's worth our 03 w/60K started locking up and shearing belts.
Get ready your will be next.
D
Old 08-13-2006, 01:57 AM
Beastmaster's Avatar
Beastmaster is off the scale
Default Re: AC Receiver / dryer Install Instructions
Drier/Receiver - pretty easy.
You'll see a can that looks like this:
http://www.ackits.com/partimages/accum/49123.jpg
Or this:
http://www.ackits.com/partimages/accum/49122.jpg
Ensure you have a generic GM O-Ring kit.
There's a side mounted pressure switch. It's attached to a standard schrader valve hookup. Unhook it from the wiring harness. Take a wrench, remove it from the schrader valve. Transfer it to the new unit. Use Nylog or GM spec high viscosity PAG oil to lubricate the threads.
As for the other parts - just unscrew the input/output sides of the drier. Replace O-Rings. Lubricate with Nylog or GM spec high viscosity PAG oil, reattach.
Ensure you add an additional 2 ounces of PAG oil to the system to replace the drier. Just add it to the compressor, you'll be fine that way.
As for the Orifice tube - I've never replaced one on an H2 yet. Sorry...
M101A2 Trailer
