Old 08-16-2006, 04:20 PM
Mojosan's Avatar
Mojosan Mojosan is offline
Mojosan is on a distinguished road
Default Little help please...New H1 owner here
Hello,
I'm glad I found this forum, I've been going through a lot of the old threads and it seems great.
Can anyone offer me some advice on my 2001 H1 Wagon?
- How do you aim the headlights? I see that there are 2 screws of 2 different sizes each.
-What is the best air pressure for street driving and should I adjust the pressure for highway driving?
- Is there a good place for accessories? I'm looking for racks for over the wheelwells and the console between the rear seats. I found Teakatoys.com but their prices seem really high. (they are almost 100% more on the husky cargo liner I bought)
-Why are the running light cutouts on the hood assymetrical?
Thanks, and I'll look forward to your answers and to being an active member here.
Here is a pic: http://aycu30.webshots.com/image/274...7376982_rs.jpg
2001 AMG H1
2004 Cadillac Escalade ESV
2006 BMW 525xi
2006 Mercedes SL500
Old 08-16-2006, 08:32 PM
Aubs's Avatar
Aubs Aubs is offline
Aubs is off the scale
Default Re: Little help please...New H1 owner here
Nice truck! I cannot answer most of your questions.
You could try Bluehummer.com or Lynchhummer.com's adventure accessories.
If you mean the turn signal lamps on the front being assymetrical, that extra space on the drivers side is for the black out light, a hint of the vehicle's military design and heritage.
~2005 Stealth Gray H2 SUV.
Old 08-16-2006, 08:37 PM
One of the screws probably adjusts vertical and the other horizontal. Just a guess.
As to the tire pressure, go by what's on the tire. You can go above it some, say another 5 lbs. But I don't own an H1, so I'm sure someone else with one can anwer you with more specifics.
Welcome aboard.
Old 08-16-2006, 08:48 PM
Aubs's Avatar
Welcome aboard.
I would say go by what's on the door. Door or somewhere in the door sill. Maybe check your owner's manual as well. My only concern is tire listed pressure would seem not to be based on vehicle weight or dynamics, since the same tire could be used on a multitude of vehicles. Or list Max PSI.
Old 08-16-2006, 10:30 PM
I didn't say DOOR? Odd.
Old 08-16-2006, 10:47 PM
ssgharkness020147's Avatar
Why do the need to be adjusted in the first place, they usually dont come out of adjustment. Your buckets could be rusted out.
Do you have GSA's? Either way a good number when the tires are cold (first thing in the morning) is 30PSI in the front and 40 PSI in the rear
You'll probably have to just bite the bullet and fork up. H1's acc. are not cheap at all.
I could not tell you.
Welcome to the board. Where are you from?
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 08-16-2006, 10:57 PM
Aubs's Avatar
Wow, I'm confused. Just look at my avatar!
Old 08-17-2006, 06:25 AM
If you're running MTRs you'll probably like the ride of 35-40psi.
Old 08-17-2006, 07:23 AM
The tires in the H1 rise up about 5 PSI once they are warm, hence the 30 PSI in the front and 35 in the rear when they are cold. But, you are right 35-40 PSI is ideal, both for tire wear and comfort. Unless he has changed the tires on his truck he still has your personal favorite tires. Goodyear GSA's. (which wear best at 35 PSI in the front and 40 in the rear when warm)
-007=
Old 08-17-2006, 01:28 PM
Mojosan's Avatar
Thanks for the input.
I'm running run flat GSA's with CTIS. I had been using the 35/40 setup (at cold) but when the tires warmed up at highway speeds I noticed a "drumming" sound from the rear. Lowering the pressure to about 39 stopped it.
As far as the lights...they are just out of alignment. Nothing is rusted anywhere.
And I did bite the bullet and ordered a bunch of goodies from Teakatoys.com last night.
Truck (and I) are in Southern NJ.
Again, thanks for the input. Much appreciated.
2001 AMG H1
2006 BMW 525xi
2006 Mercedes SL500
Old 08-17-2006, 08:42 PM
01 was a good year, 02, 03 hmmmmm. Enjoy that bad boy
Old 08-18-2006, 03:18 AM
Ground hawg's Avatar
Ground hawg Ground hawg is offline
Ground hawg is an unknown quantity at this point
nice truck. try bluehummer.com for spair parts and some accesories.
I run my H1 at 30 front and 35 rear when cold no mater whar tires I have on. you might want to get a good sound system if you start running with agresive tread though, does get a tad noisy.
Old 08-19-2006, 06:54 PM
andski's Avatar
andski andski is offline
andski is off the scale
Originally Posted by Mojosan
-Why are the running light cutouts on the hood asymmetrical?
If you are talking about the driver side recess, the HUMVEE has a special light that mounts in that area to allow them to run at night w/o their headlights on. It is not available from the factory on the H1.
Old 09-01-2006, 04:05 AM
hmcoleap's Avatar
hmcoleap hmcoleap is offline
hmcoleap is on a distinguished road
Welcome aboard - Answers to your questions are mixed in below...
Hello,
Tighten and loosen the screws - if it goes the wrong way, reverse the direction you are turning that screw
Depends on the tire. I actually had best luck with GSA's at nearly 50psi.
I run wider off-road tires at much lower pressure to get even wear - most around 25psi. Tell us what your tires are and you will get more specific answers.
It really depends on what item you are looking for, but here are a few to go browse around at:
Adventure Accessories (Lynch Hummer)
BlueHummer Outfitters
Rubberduck4x4
Predator Motorsports
And of course, anyone else who advertises in either Ultimate Hummers Magazine or on http://hummer.offroad.com - (yeah, so I might be biased since they pay some of my bills).
Military blackout light mounts in the "extra space" on the driver's side on HMMWVs - they share the same hood as the civilian trucks.
-- Manny
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
manny(at)serious4x4.com
http://www.serious4x4.com
Old 09-06-2006, 12:09 AM
Trail Monkey's Avatar
Trail Monkey Trail Monkey is offline
Trail Monkey is on a distinguished road
there are a lot of backorders for H1 accessories these days because of SMA closing up.
ive had the best experience with these guys
www.bluehummer.com
www.rubberduck4x4.com
if you need any specific recommendations i have a wagon also and recently outfitted it. email me..
if your ready to turn that nice truck into an offroader. im on LI, lets go to paragon.
