Old 08-16-2006, 05:20 PM
KB7TCV KB7TCV is offline
KB7TCV is off the scale
Default Need + Wire in rear
Looking for a + wire that is hot all the time in the rear gate area. Needs to be able to handle 10-12 amps. Am working on install of Ham Radio Equipment.
Old 08-16-2006, 05:24 PM
Default Re: Need + Wire in rear
Sounds painful. Get out your multimeter and start checking the trailer harness.
Old 08-16-2006, 06:15 PM
You could tap off either your lead for the 12v lighter plug in in the back. Better Find your leads for trailer and tap into that and bring up.
Old 08-16-2006, 09:55 PM
lotus4s's Avatar
lotus4s lotus4s is offline
Sounds painful.
Old 09-01-2006, 10:42 PM
Klint's Avatar
Klint Klint is offline
Hey man, what I did was ran a wire from the front under the the truck following the break line. I have Co-ax and a 8g wire running back there...
Klint T.
2007 Black Lux, Blinged out
