Old 12-28-2005, 01:37 PM
Harley's Avatar
Harley Harley is offline
Harley is off the scale
Anyone had any personal experience with these mercury or shot filled plates that go between the wheel and hub? I've read all I can find about these and there seems to be pros and cons... depending on who writes the note / article ( humvee.net ).
K
Harley's Avatar
K
Old 01-21-2006, 11:39 AM
Joe Joe is offline
Joe is off the scale
I have the centramatics and they do help a bit. I have never had the pleasure of seeing a tremendous improvement that others have. In the end I think the biggest factor in using these and getting maximum benefit is having a true set of rims and the tire itself. This is the real challenge, rims and tires. The won't fix an out of round tire (common problem) or a bent rim (common problem if you off-road on rock and/or use the steel rims)
2001 H1 Opentop
2003 H2
Homepage:
http://www.hummerh1.net
Old 12-31-2005, 12:09 PM
They will smooth out what is considered a 'slightly' more than normal vibration, but won't cure a violent shake. If you've got GSA's, don't waste the money--you're fighting a losing battle. If you've got MT/R's and are looking to smooth out, you'll see a little improvement. Just my $.02
Old 01-03-2006, 10:59 PM
Ground hawg's Avatar
Ground hawg Ground hawg is offline
Ground hawg is an unknown quantity at this point
Got mine 4 months ago from centramatic $300.00. personaly I wouldn't be without them. much better than waights that can come off, and dont compontate for any offroad debris that you may pick up along the trail.
